Multiair problem!
General messages
Grandy
Multiair problem!
Post by Grandy » 31 May 2014, 08:44
I have Mito qv -10 and MES 1.9. Now i have a small problem when the MES to inform that> Uniair actuator dispersion correction Status - in progress! This is self-inflicted, and I can not get it off. I understand that MultiEcuscan can not get it out? Check engine light flashes continuously and the start / stop does not work! I hope someone help me because my english needs little practice and thats why sort message ;)
Kishen
Re: Multiair problem!
Post by Kishen » 09 Jun 2014, 06:45
Grandy wrote:I have Mito qv -10 and MES 1.9. Now i have a small problem when the MES to inform that> Uniair actuator dispersion correction Status - in progress! This is self-inflicted, and I can not get it off. I understand that MultiEcuscan can not get it out? Check engine light flashes continuously and the start / stop does not work! I hope someone help me because my english needs little practice and thats why sort message ;)
I have the exact sam problem..
Grandy
Post by Grandy » 09 Jun 2014, 07:16
Are there any links or articles related to this topic?
Kishen
Post by Kishen » 09 Jun 2014, 07:26
I have searched, and found nothing...
there has to be a way to clear this error or rectify it.
i have even posted on alfaowner....http://www.alfaowner.com/Forum/south-af ... -mito.html
awaiting a response/help.
Kishen
Post by Kishen » 11 Jun 2014, 06:13
took car to dealer and they sorted out the error.
also apparently multiecuscan 2.0 does this correctly with no errors.
Dagooz
Post by Dagooz » 19 Mar 2016, 13:17
Just used MES 2.9 to perform the "oil change" option on my Mito QV. I now appear to have the same problem. "P1320 - Uniair module learn" is present and under parameters the "UniAir actuator dispersion correction status" is "In progress". Had the engine idling for 15 minutes, no change. Should we simply not execute the "Oil change" when we actually do a physical oil change or what is the situation.
And yes... I know this an old topic ;-)
Dagooz
Post by Dagooz » 22 Mar 2016, 20:22
Problem solved. Apparently the "Oil change" option should never be executed. Alfa Romeo no longer has that option in their testers and it is only old and unoriginal testers that pose a risk by having this option. There is a risk that performing "Oil change" causes a fault. The only way to reset it is by updating already has the newest software there is only one option left: fitting a new ECU.
Michelange37
Post by Michelange37 » 31 Mar 2016, 10:18
I have the same problem than Grandy with MES 3.0. Dagooz explain how to reset this error, but I'm french. I don't understant what he say perfectly.
Can you please explain more simply?
nando
Post by nando » 14 Oct 2020, 21:00
Ive done the service on my Fiat Punto Evo, I connected a Autel scanner to reset oil light but after that the MIL light started flashing intermitente and I got a code p1320 multair module learn.
How can I reset it. many thanks
