Hi, i have a fiat palio top fire 2005 1.3 16v and i am trying to use the multiecuscan whit the model/version PALIO RST1.2 16v and didn´t work, later i tryed whit PALIO RST 1.6 16v and now connect but i have this problem: "Invalid Iso Code" and the program givme two opcion, Y to continue and N to abort, i press Y and i have acces to the information, but i can´t see nothing in the parameters list, same whit Graph and Actuators. Some one know how i can solve this?
Thanks and sry about my english, i am from argentina.
invalid ISO code!!
Re: invalid ISO code!!
Hi albertodg2 ,
You can see message "Invalid ISO code " in case when ECU of the car which you are trying to connect is not correct.
Just for example for 2.4 JTD engine with Bosch EDC15C7 valid ISO codes for are:
% System ISO code(s):
% FD 86 0D 80 E5
% FD 86 0E 80 E6
% FD 86 10 80 68
% FD 86 13 80 6B
% FD 86 15 01 6E
% FD 86 16 01 EF
% FD 86 23 83 FE
% FD 86 29 83 04
% FD 86 2A 83 85
% FD 86 2C 83 07
% FD 86 2F 83 8A
% FD 86 31 83 8C
% FD 86 32 83 0D
% FD 86 8C 80 64
% FD 86 8F 80 67
% FD 86 91 80 E9
% FD 86 A2 83 FD
% FD 86 A8 83 83
% FD 86 AB 83 86
% FD 86 AD 83 08
% FD 86 AE 83 89
% FD 86 B0 83 0B
In your case you may have very simillar ECU but it's not fully supported by this software.
May be you can read stored errors or some of the realtime engine parameters, but this is only a sugestion.
For exaple i tryed to connect to my Lybra Airbag ECU with wrong Airbag model from list i also receive Invalid ISO code message, but i can connect and to check for errosr for example.
I hope that this info helps.
% FD 86 0D 80 E5
% FD 86 0E 80 E6
% FD 86 10 80 68
% FD 86 13 80 6B
% FD 86 15 01 6E
% FD 86 16 01 EF
% FD 86 23 83 FE
% FD 86 29 83 04
% FD 86 2A 83 85
% FD 86 2C 83 07
% FD 86 2F 83 8A
% FD 86 31 83 8C
% FD 86 32 83 0D
% FD 86 8C 80 64
% FD 86 8F 80 67
% FD 86 91 80 E9
% FD 86 A2 83 FD
% FD 86 A8 83 83
% FD 86 AB 83 86
% FD 86 AD 83 08
% FD 86 AE 83 89
% FD 86 B0 83 0B
Club Alfa Romeo Bulgaria member / Lancia Club Bulgaria member
Lancia Lybra 2.4 JTD@140 Hp 2001
