Errors do not clear
General messages
djemileo
Errors do not clear
Post by djemileo » 15 May 2013, 18:01
Hello. Sorry to my English, use online translate. I am a novice among you, live in Ukraine. In 2012 i buy Fiat Brava 14v 1996, with the included indicator of Airbag. I took Vag-com 409.1 read errors, here they
ECU ISO Code: 26 86 02 15 98
09.05.2013 20:13:52
CONNECTED TO:
Fiat Bravo/Brava 1.4 12V
BREED Airbag
ECU ISO code: 26 86 02 15 98
FIAT drawing number: 46413633
Software version: 1.6
Hardware version: 1.5
ECU programming date: 19.01.1996
READING ERROR CODES:
1: 02 - Battery Voltage too low
No help available
2: 05 - AIRBAG warning lamp in S.C. to GND or O.C.
No help available
3: 0B - Driver's squib in O.C.
No help available
4: 01 - Control unit faulty
No help available
5: 04 - AIRBAG warning lamp in S.C. to +V
No help available
6: 05 - AIRBAG warning lamp in S.C. to GND or O.C.
No help available
CLEARING STORED FAULT CODES...
I can not delete errors. The program writes that some errors did not erase and press again F10. For us in Ukraine specialists are not quite present therefore ask for a help for you
Juggers2k
Re: Errors do not clear
Post by Juggers2k » 21 May 2013, 14:45
Clearing the fault codes won't fix the faults.
The faults you have there are short to ground, short to positive, open circuit, control unit faulty - they all point to wiring faults on the car, or possibly a catastrophically failed airbag controller which is shorting out all the other components.
Although you can send a clear command, if the Airbag ECU is reporting "control unit faulty" it may not be able to process that command.
Even if it can process it, if the system is full of wiring faults, the fault codes will immediately come back again.
Have the airbags been detonated on the car?
Unless you have a series of wiring faults, it sounds like your airbag ECU may be dead.
Post by alfa156sarajevo » 21 May 2013, 20:29
You should be happpy that you could access to your airbag module.
I tried Bravos from year 1996 or year 1997 but still did not have any luck.
As Juggers2k said you have problem with airbag installation or airbag ecu.
If it is problem with airbag ecu in most cases it can be reprogrammed...
