proxi alignment procedure
General messages
Beaniesbcfc
Post by Beaniesbcfc » 26 Feb 2013, 14:52
Hi there i have a alfa 147 and just put a new pioneer x8500xdab head unit in and now i can not do a proxi alignment procedure as it keeps failing on dash NQS node. It just says timed out can some one help me out please
Re: proxi alignment procedure
Post by Alfaeddy » 26 Feb 2013, 18:58
I think you need a CAN bus adapter, of your new Pioneer x8500
The body computer is missing, and therefore stops the teaching (Proxi Aligment)
I think this is such an adapter
http://www.ebay.de/itm/ALFA-ROMEO-147-G ... 2eb7e4cc99
Beaniesbcfc
Post by Beaniesbcfc » 26 Feb 2013, 19:33
Hi there and thanks for the reply. But it sees The body computer and it worked fine on my over pioneer unit
Post by Alfaeddy » 26 Feb 2013, 22:05
Hmmm .. ?! OK :|
So you have no errors in the display?
Then I would make my first time not worry about terminating proxy setting
Beaniesbcfc
Post by Beaniesbcfc » 01 Mar 2013, 10:44
But i think thats why my battery is going flat as it's not turning the power off right
bope
Post by bope » 04 Mar 2013, 14:29
I changed my instrument panel in my ALFA147 1.6, but now I have ASR error and my tempomat not workable. If I will buy multiecuscan, the proxy alignment feature can help me to syncronize nods/remove error? The second problem is flashing odometer and an incorrect km value...
bope
Beaniesbcfc
Post by Beaniesbcfc » 04 Mar 2013, 18:08
Yes if you get the paid version that should fix that for you
bope
Post by bope » 05 Mar 2013, 07:49
thanks for the reply. I just forget to notice, that my car don't have ASR...so this is not just a "simple" error like airbag or MIL... can proxy alignment do the trick in this case too?
thanks
Post by alfa156sarajevo » 05 Mar 2013, 12:25
Had a similar case... After replacing old dash with newer one, ASR lamp always did stayed on + on the display I could see the message "ASR faliure".
Did a PROXY did not had any luck.
Also keep in mind that on most petrol cars function of enabling cruise controle (tempomat) is not available...
Did not check new version of MES but older on did not had that option...
bope
Post by bope » 07 Mar 2013, 11:05
Thanks for the reply! So I can forget the proxy alignment...in this case for what can I use proxy alignment?or is just an error in application(Multiecuscan)? maybe any other solution to fix it????
about tempomat: before my tempomat was workable, I think only ASR error tilt it
