alfa 147 p1191 faultcode
Posted: 18 Nov 2012, 20:33
by brera32
Hi @ all
URGENT !! Just 15 minutes ago my Alfa 147 JTD 16v quit running-
Fault code is P1191 Fuel pressure .
Can anybody tell me which sensor it is.
Is it the rail pressure sensor, or is there another sensor?
Thanks in advance
also you can answer on my PN. gta32@gmx.at
Re: alfa 147 p1191 faultcode
Posted: 23 Nov 2012, 12:44
by devc
It is the rail pressure. The sensor sits at the end of the fuel rail. Is there enough fuel in the tank? (heh-heh! sorry but it happens).
Is the cambelt ok? Check for fuel leaks from the high pressure pump to the fuel rail and the pipes from the fuel rail to the injectors.
Finally disconnect the fuel line from the high pressure pump to the fuel rail, switch on the car,(dont start) and check that fuel comes out from the low pressure pump in the tank. Possibly also a dirty fuel filter or water/petrol in the system.
Posted: 25 Nov 2012, 17:33
by alfa156sarajevo
devc is right!
Fault named P1191 - Fuel pressure sensor - could be caused by fuel pressure sensor, or wiring, or problem in fuel system or problem with ECU (rearly).
Posted: 06 Jan 2013, 09:43
by brera32
First of all... THANKS FOR YOUR SUPPORT
Now the Solution..
The Timing belt was torn...
Unfortunaly MES didn`t show me the Camshaft sensor Fault.. just the Fuel pressure Fault. This was very confusing to me..
Thanks Brera32
