Multiecuscan 1.0 RELEASED!!!
General messages
Post by yani » 10 Aug 2012, 14:33
As you probably noticed the software is now called Multiecuscan.
Please note that this change does not affect the licenses. All licenses will continue to work with the new software. The licensing policy will also remain the same.
You can download Multiecuscan 1.0 from our new web site - www.multiecuscan.net
Please DO NOT deactivate Multiecuscan before installing Multiecuscan! Simply download and install the new software. It will take the license info from your Multiecuscan installation. You can uninstall Multiecuscan AFTER that.
The new version comes with the following changes:
- Improved SCAN function
- Restructured vehicle database
- Added 'priority' for parameters when recording data
- Added 'Torque sensor calibration' for Delphi Electric Steering (500, Grande Punto, Punto Evo, Mito)
- Support for Marelli/Hella climate control (Lybra)
- Support for Magneti Marelli IAW 4AF/4EF GAS Injection (Multipla Bipower, Doblo Bipower) (Full support)
- Support for Magneti Marelli IAW 5AF GAS Injection (Punto Bipower, Panda Bipower) (Full support)
- Support for Magneti Marelli IAW 5SF CF4/EOBD Injection (Stilo, Palio, Linea, Doblo, Ypsilon, Musa) (Full support)
- Support for Magneti Marelli IAW 4SF Injection (Palio, Linea) (Full support)
- Support for Landi Renzo LC02 LPG Injection (Bravo, Punto, Grande Punto, Punto Evo, Panda, Mito, Ypsilon)
- Support for Metatron 6A0/EOBD CNG Injection (Punto Bipower, Panda Bipower, Doblo Bipower)
- Support for Metatron 6A0 CNG Injection (Punto Bipower, Doblo Bipower)
- Support for Metatron 5D0/EOBD CNG Injection (Multipla Bipower)
- Support for Driver's Seat LEAR (Stilo, Croma, Bravo, 159, Brera, Delta) (Info and DTC only)
- Support for Passenger's Seat LEAR (Stilo, Croma, Bravo, 159, Brera, Delta) (Info and DTC only)
Regards,
Aron96
Re: Multiecuscan 1.0 RELEASED!!!
Post by Aron96 » 10 Aug 2012, 17:24
Hello Yani, as always do a great job,
thanks for your commitment to the new project that changed the
my English is translated with google I hope you understand what I write
regards
96 Aron
Post by alfa156sarajevo » 24 Aug 2012, 19:46
Yani,
Just one question for you, does the MULTIPLEXED users have additional forum - folder with topics just like registered user do have it? :roll:
Post by alfa156sarajevo » 03 Sep 2012, 17:39
There is a bug in MES 1.0.
When I go to search for specific model example Ducato, and I start to type "Duc" I got "Doblo".
In previous version there is no this bug. Would be nice to fix it! ;)
Post by alfa156sarajevo » 11 Sep 2012, 17:46
There is another bug in MES 1.0.
All log files, or as some of as calling them the reports, are still saved as "FESLog_12...".
Maybe they should be a "MESLog_...."! Would be nice to fix it!
Post by alfa156sarajevo » 11 Sep 2012, 17:51
And one more thing...
On Fiat Panda 1.2 from 2005 Service Interval Coupon is working just fine...
But if you want to edit date and # of kilometers until next service, this function is not working...
Maybe Yani you can check it and do more tests...
ZOCOPEO
Post by ZOCOPEO » 20 Sep 2012, 20:00
hello
in Punto evo and Mito . Steering Torque sensor not working calibration
Post by yani » 21 Sep 2012, 14:10
ZOCOPEO wrote:hello
Did you get an error message?
ZOCOPEO
Post by ZOCOPEO » 13 Oct 2012, 01:07
hello
  message, set not done. my machine does. what multiscan and not send the same data. my machine and the program does not make the adjustment
thanks
