lampeggio spia olio 500 mjt - Oil warning light flashing
General messages
boliderosso
Post by boliderosso » 12 Nov 2011, 20:53
salute, vorrei acquistare la versione registrata, ma probabilmente non riesco a vedere, riesce a spegnere la spia olio che indica il degrado olio in centralina su una 500 mjt del 2011?
hallo can Fiat Ecu Scan shut down Oil warning light flashing? on fiat 500 mjt year 2011
thank you for the answers
Aron96
Re: lampeggio spia olio 500 mjt - Oil warning light flashing
Post by Aron96 » 13 Nov 2011, 10:21
Hello Boliderosso, you can purchase the works and also reset the service oil degradation, but you can also check the official website that tells you how your car, but if you always work your cable elm that you can still try the test elm with a limited version,
regards Aaron :D
dallas140cv
Post by dallas140cv » 14 Nov 2011, 09:41
The oil warning light can be deactivated only with full version.
boliderosso
Post by boliderosso » 14 Nov 2011, 11:09
ok, thak you
