Various OBD II VAG COM KKL cables
General messages
amiko
Post by amiko » 23 Oct 2011, 07:25
What do you think about this cable:
http://cgi.ebay.com/VAG-COM-KKL-409-1-O ... _802wt_698
Re: Various OBD II VAG COM KKL cables
Post by Alfaeddy » 23 Oct 2011, 18:08
This can be used, as well as many other KKL
greetings Eddy
amiko
Post by amiko » 23 Oct 2011, 21:01
Alfaeddy wrote:Hello
greetings Eddy
you mean, it can be used for Alfa/Fiat/Lancia right?
Juggers2k
Post by Juggers2k » 24 Oct 2011, 09:24
greetings Eddy
The ones listed as "KL" in the supported vehicles list, yes.
Post by Alfaeddy » 24 Oct 2011, 09:42
greetings Eddy
Right :)
Post by alfa156sarajevo » 26 Oct 2011, 11:04
amiko wrote:What do you think about this cable:
Looks OK! But it is too expensive... :o :roll: :o
Juggers2k
Post by Juggers2k » 26 Oct 2011, 12:36
alfa156sarajevo wrote: Looks OK! But it is too expensive... :o :roll: :o
Depends what you're after really.
I've used a £5 cable and a £20 cable, and you can feel which one's going to last longer before you even connect to car.
The very cheap cables are cheap for a reason - they're built down to a price.
azulou
Post by azulou » 29 Oct 2011, 19:18
hi,
can i use this cables in bravo TD100?
thanks
Post by alfa156sarajevo » 30 Oct 2011, 13:08
azulou wrote:hi,
thanks
I think you can use VAG COM KKL USB interface for your Fiat Bravo TD100.
You will also need an 3pin adapter!
Before you buy anything just check your vehicle on this list: http://www.multiecuscan.net/SupportedVehiclesList.aspx
Cheers ;)
azulou
Post by azulou » 30 Oct 2011, 15:27
thanks
