Multiecuscan 3.3 RELEASED!!!
General messages
Aron96
Re: Multiecuscan 3.3 RELEASED!!!
Post by Aron96 » 19 Oct 2011, 13:26
Yani great job: thanks :P :P
EnIgMa
Post by EnIgMa » 19 Oct 2011, 20:43
a lot of improvements :D
Hubert S
Post by Hubert S » 23 Oct 2011, 09:44
Thanks !!!
Noticed that Lancia Thesis 2,4 Mjet Aisin Autom gearbox was added.
Missed this before. Will test later. Many owners complain about late up-shifting.
Try to adjust.
Keep up good work.
Hubert S
Post by Hubert S » 23 Oct 2011, 15:26
Did reinitialisation of tranny, and shifting is now much better(sooner).
I know this can be done manually (see E-Learn Thesis) and that coolingfluid temp. as well as
tranny atf temp should be within certain limits. Now we can check both thru FES!!
So i did the reset when both temps were within range, just to be safe!!
Great, forever in your debt, Yanni !!!
olahaye74
Post by olahaye74 » 24 Oct 2011, 11:54
I own an Y10 with the references below, will this new version support Bosch MA1.7 (using ELM327 V1.4a)
I've read that it supports MA1.7.3, but what about MA1.7? is it the same?
Connecting My interface using a 3pin adapter to my Y10 seems Ok as the TX and RX leds are blinking on both sides, (while they stay steady on my Xsara VTS HDi 110 with VAN protocol). I've tested V 3.2 and my Y10 is not recognized. will this 3.3 recognize it?
Y10 references:
Mode l: Y10 LXie 1.1 litre
Year: 91-95
System: Bosch MA1.7
OE Ref. No.: 0 261 200 716
VM Ref. No.: 7778785
ATP Pt. No.: XEBS0716
Many thanks for your help.
Best regards,
Olivier.
Dimko
Post by Dimko » 26 Oct 2011, 18:52
beowolf wrote:still no support for ECU Marelli IAW 1AF for fiat brava 1.6 16V ??????? Why???? I'm ready to buy FES if u add this car. Lots of ppl will buy it I think...
I completely agree. Support Fiat Brava 1.6 16V is necessary.
Dimko
Post by Dimko » 26 Oct 2011, 18:57
olahaye74 wrote:Hi,
Y10 references:
Year: 91-95
System: Bosch MA1.7
Best regards,
Olivier.
MA1.7.3 works only with KKL/VagCom and OBDKey 1.40.
ARomeo
Post by ARomeo » 28 Oct 2011, 18:39
DID YOU FIX PROBLEMS WITH DELPHY CLIMA CONTROL?
exportautoparts2010
Post by exportautoparts2010 » 30 Oct 2011, 02:33
Good,it works.thanks :D
ARomeo
Post by ARomeo » 01 Nov 2011, 20:48
And what about with climatronic control bugs?
