Grande Punto Cruise control aftermarket
General messages
dimitar_ak
Re: Grande Punto Cruise control aftermarket
Post by dimitar_ak » 11 Feb 2013, 13:05
This is so called "clock spring cable", but here it's integrated with the stalk unit. In my case this cable was the reason to start the CC project. I lost left buttons first, then right buttons and finally the Airbag. The cable was broken apart and no repairable. The CC stalk unit is only 15-20Eur more expensive than the normal stalk.
kris
Post by kris » 07 Mar 2014, 01:59
Does anyone still has the guide from puntomag.fr, because the site isn't online anymore. I can't figure out how to connect the 41 pin.
regi54
Post by regi54 » 07 Mar 2014, 08:12
You can find a copy of this tuto here:
http://italian-automobile.forumprod.com ... -t250.html
kris
Post by kris » 07 Mar 2014, 12:24
regi54 wrote:Hello,
Thnx for the link, but when it comes to the detailed connection of the cable it also reffers to puntomag.fr. I don't understand which cable I should link. Is it the 41th cable from behind the obd connection (h) to one of the eight cables coming from the new stalk (which one of the eight)?
dimitar_ak
Post by dimitar_ak » 07 Mar 2014, 19:23
In my case there was not cable on pin 41. I had to make a new cable link. And yes the conector is on the rear side of the body.
kris
Post by kris » 09 Mar 2014, 02:50
dimitar_ak wrote:In my case there was not cable on pin 41. I had to make a new cable link. And yes the conector is on the rear side of the body.
But can you tell me from where to where this cable goes. What do you connect the cable behind nr 41 with
jimskerle
Post by jimskerle » 20 Jun 2014, 14:22
[hello i have grande punto 1.6 diesel 2009 with body computer 518263170. can i install cruise control or it is impossible?
i searched the forum and i saw that there are many topics , but i am a little confused. so if someone can answer at least if i can do it , and if so how
thanks
boural
Post by boural » 24 Sep 2014, 17:02
Hello every body, My grande punto 1.3 mjt 75 dynamic, N° ZFA19900001559460 manufactured (info from EPER) Data prod.: 28/8/2009 was already with cable between pin 41 and pin 8.
I changed the "commodo" with a new one with the cruise control, lever I activated with multiecuscan 2.1. Every thing works : green led, + message on OBD "cruise control on/off" but no action on speed!!!
I checked with multiecuscan the clutch, two brake signals and the action on lever everything is working, but impossible to memorise a speed (I use carefully the lever on/off + action on cruise + some seconds).
Could you please give some ideas/ experience
Thank you in advance
boural
Post by boural » 06 Oct 2014, 12:21
Hello, I thought a lot on my issue and perhaps I have an idea. The 1.3 mjet can be equipped of different tyre size: 175/65R15 or 185/65R15. One year ago I installed 185/65R15 on the rear and I still have 175/65R15 on the front, the difference in perimeter represents +2.1 % for 185.
I think that the ECU receiving as an info a different speed coming from front & rear wheel it refuses to stabilize the speed.
What do you think?
Nevertheless I will be fixed on 10th of October because I will install 185/65R15 on the front.
I will keep you posted.
Brgds
