USB VAG COM INTERFACE
General messages
EMILIO13
Postby EMILIO13 » 07 Nov 2010, 12:17
Hi all !
I have a problem with the USB VAG COM interface ! I want to know if it is possible to use the Multiecuscan programm with the USB port ? I am working under WINDOWS 7.
Many thanks for your help.
Forza Italia
Re: USB VAG COM INTERFACE
Postby alfa156sarajevo » 09 Nov 2010, 15:34
Yes it is possible to use Multiecuscan programm with the USB port! ;)
What kind of VAG KKL cable do you have? USB or SERIAL?
www.alfadiagnostik.com
Diagnostic for Alfa Romeo, Fiat and Lancia cars
Repairing City Servo System - Power Steering on Fiat and Alfa cars
Airbag ECU reset - all vehicles, all cars, all brands and all models
EMILIO13
Postby EMILIO13 » 11 Nov 2010, 16:50
I have USB cable but the program do not recognize it !!!!!! Have to change something in the parameters ???
lenivec
Postby lenivec » 16 Nov 2010, 22:17
have you install correct driver?
Postby alfa156sarajevo » 18 Nov 2010, 12:00
So did you install all drivers that came with this VAC COM USB cable?
If you did installed all the drivers for VAG COM you just need to modify the com port! Go to Start>Control Panel>System>Hardware>Device Manager>Ports> and than set the settings as shown on web page: http://www.multiecuscan.net/HowToUse.aspx!!!
After that you need to modify you VAG COM cable so can connect to ABS, AIRBAG or ENGINE ECU.
See this web page: http://forum.multiecuscan.net/viewtopic.php?f=5&t=255!!!
Cheers ;)
peko
Postby peko » 22 Nov 2010, 08:47
hi friends
he must also solder pins ?
anybody can say wihch pin shint with which pin ?
thank you
Postby alfa156sarajevo » 24 Nov 2010, 12:20
more info you can find here: http://forum.multiecuscan.net/viewtopic.php?f=5&t=255!!!
Return to “General”
Who is online
Users browsing this forum: No registered users and 3 guests
