Airbag profile
General messages
rafi532
Airbag profile
Post by rafi532 » 13 Sep 2010, 19:09
Hi again,
I'd like to solder pins in order to read an airbags error.
in my cable, pin's numbers are not written on the plug, so I have photo of both sides of the plug.
can someone tell me what are the pin's numbers:
and what pins I have to cross in order to read the airbags ?
Thankes
Re: Airbag profile
Post by s130 » 14 Sep 2010, 10:34
As you look at your TOP picture then this is how the pins are numbered
a) The bump in the connector edge is located on the Pins 9 to Pins 16 side of the connector
b) Front LEFT is Pin 9 and Front RIGHT is Pin 16
c) Rear LEFT is Pin 1 and Read RIGHT is Pin 8
d) You currently have Pin 4 and Pin 5 linked (these are the signal and chassis ground pins)
As has been discussed, and as detailed in the "How to Use" ( http://multiecuscan.net/HowToUse.aspx ) then for NON CAN based systems then:
For Airbags connect Pin 7 to Pin 3
For ABS connect Pin 7 to Pin 1
For Body ECU, EPS connect Pin 7 to Pin 9
IT IS NOT RECOMMENDED to Connect Pins 7, 1, 9 AND 3 altogether at the same time!
7 to just 3 is OK
7 to 1 and 9 is OK
rafi532
Re: Airbag profile
Post by rafi532 » 14 Sep 2010, 11:46
thank you,
if I understand, it's looked like that:
Re: Airbag profile
Post by s130 » 14 Sep 2010, 17:13
NO NO NO
Your 1 to 8 is ACTUALLY 9 to 16
Your 9 to 16 is ACTUALLY 1 to 8
Your red wire is linking 10 and 15 !
rafi532
Re: Airbag profile
Post by rafi532 » 14 Sep 2010, 19:06
sorry,
of course, you actually write it very clear, I didn't read it right.
thanks
rafi532
Re: Airbag profile
Post by rafi532 » 16 Sep 2010, 07:14
Hi again,
I've linked 3 and 7 pin - nothing happen
I've changed the interface to obdKey 1.4 as I'd asked to do.
all old option are working but when I try to connect airbags I get NO ECU FOUND CHECK YOUR CABLE .....
Re: Airbag profile
Post by yani » 16 Sep 2010, 07:34
What type is your interface?
It is not possible to connect to the airbags with ELM 327 interface.
rafi532
Re: Airbag profile
Post by rafi532 » 16 Sep 2010, 12:11
I have alfa 147 1.6 ts 120HP year 2002.
the window on connecting say that I have to use k-line/vagcom or odbKey interface.
when I choose k-line/vagcom there is no connction at all in any option (engine/service ...) and when I choose odbKey 1.4 every other options are working but the airbags still not connecting.
I'm sure I've solder it right.
spetsnaz_bg
Re: Airbag profile
Post by spetsnaz_bg » 27 Sep 2010, 15:23
Имам нужда от помощ някой владее ли Български .
Предварително благодаря
