Support for Marea 2.4 2003 (Motronic 3.1) from Brazil
General messages
rodrigo-poa
Post by rodrigo-poa » 05 Jul 2010, 06:23
Hello people,
Anybody know if I connect to the Marea 2.4 20v 2003 (Motronic ME 3.1) with multiecuscan?
The car is not in the list, but many of the same injection system are.
In Brazil the Fiat Marea have the follow versions:
2.4 20v (2001-2007)
1.8 16v (1999-2003)
2.0 20v (1998-2001)
2.0 20v Turbo (1999-2007)
If exist support, i buy the cables.
Tks,
Rodrigo
samuelprados
Re: Support for Marea 2.4 2003 (Motronic 3.1) from Brazil
Post by samuelprados » 31 Jul 2010, 16:32
Hi! i'm brazilian too and i have exactly the same question! 2.4 20v fiat marea uses bosch motronic ME3.1 eobd ecu, i'm not 100% sure but i believe it is the same ecu for fiat stilo 2.4 20v.
so, the question is still up:
does it work for 2.4 20v fiat marea?
if i select fiat stilo 2.4 20v in multiecuscan will it work for fiat marea 2.4 20v?
if fiat marea 2.4 20v is not supported by fiat ecu scan, i seriously advice you guys to add it to multiecuscan supported vehicles, i know a bunch of guys that would buy it in no time if this car is supported!
waiting for a aswner!
samuelprados
Post by samuelprados » 31 Jul 2010, 16:38
Hi, i'm brazilian too and i have the exact same question!
fiat marea 2.4 20v uses bosch motronic me 3.1 eobd ecu, i believe this is the same ecu for fiat stilo 2.4 20v.
if i select fiat stilo 2.4 20v in multiecuscan, will it work for fiat marea 2.4 20v?
if fiat marea 2.4 20v is still not supported by multiecuscan i strongly advice you guys to add it to supported vehicles, i know a lot of guys that would buy the software to use in this car.
waiting for and aswer!
