Good Evening.
My first post of which I hope I can get help with.
I have a registered version of multiecuscan of which version 4.71R. I use the software generally for a Fiat. Though I have recently purchased a Jeep Cherokee 2.2 Diesel Multijet. This model is not listed in the pull down in the menu. But if I select Alfa Guilia with 2.2 Diesel engine it’s connects fine with the ELM, but a pop up occurs saying conflict in ISO code, “ Do you wish to continue “ of which I have not continued yet. I have emailed support@multiecuscan.net for advice and await a reply.
Before you ask, my Cherokee will not connect if I select the 2.0 Diesel engine even though all use a Bosch setup.
Look forward to comments or advice.
Thanks.
MultiECUScan and Jeep Cherokee
Re: MultiECUScan and Jeep Cherokee
I would continue, don't think it will cause any problems
