ELM327-USB V3.0
General messages
Re: ELM327-USB V3.0
Post by s130 » 02 Mar 2018, 09:29
The information you require is on this page:
Find your vehicle(s) and see which adapters (if any) are required.
The MES software will also tell which adapter (if any) is required when you select the unit/module you wish to connect to.
A|ex
Re: ELM327-USB V3.0
Post by A|ex » 22 Mar 2018, 11:01
Hi All,
I spent last Sunday trying to figure out why I can't connect to can based modules in Alfa-Romeo Giulietta. Engine ECU worked just fine, but I couldn't connect to Body, Service and other CAN based modules.
I noticed that many people land on this page looking for solution, but @kris post is very misleading, you don't need to remove any resistor in this version of ELM327, it's ready to work with CAN modules.
In my case the problem was that Alfa Giulietta has CAN on pins 1,9 instead of standard 6,14, therefore MultiEcuScan warns you to plug yellow adapter no.3 which 're-route' pins accordingly.
I solve that by installing mini-switch in my ELM which lets me change CAN pins between 6,14 and 1,9. Now with this MOD I can connect to all modules without any problem.
Similar MOD is described here:
https://topscantool.com/modify-mscan-el ... rscan.html
If you can't connect to any modules check your drivers first. You should have USB-COM port available in device manager and it should be available for selection in MultiEcuScan under Settings -> Interface TAB.
sam7376
Re: ELM327-USB V3.0
Post by sam7376 » 17 Nov 2019, 07:10
You can try to scan for interfaces in your multicuscan software first. Once an interface has been found you should be ok to connect. I hope this helps.
