No Adjustment actions execute
General messages
CaseSensitive
Post by CaseSensitive » 13 Apr 2018, 16:03
I purchased Multiscanecu today, to reset the oil change indicator on my 2009 Alfa Romeo 159 2.4 (210).
I was able to connect to my ELM 327 wifi with the car started at idling in neutral, and connect to the various ECUs without much difficulty, all the same, I think I will get a USB OBD cable for convenience.
While I was able to read data from the car, any ADjustment action I attempted failed.
They were:
Distance till next service
Days till next service
Oil change (I do have a DPF)
even basic tests such as turning on the oil pressure or cruise control indicators (when neither were enabled) failed to execute.
I have enclosed images by way of proof.
https://www.flickr.com/photos/43278150@N00/?
Any idea what might be going wrong?
Re: No Adjustment actions execute
Post by s130 » 15 Apr 2018, 10:57
Whilst you have an ELM device I remember on my Croma 2005 1.9MJet 150CV (same as in Alfa 159) the engine ECU functions worked much better with a proper KKL interface.
Suggest you obtain a VAG COM KKL interface and try again. The are not expensive and for some Fiats give more reliable results than the ELM emulation of KKL.
CaseSensitive
Post by CaseSensitive » 19 Apr 2018, 13:39
I bought a USB ELM327 1.4 device and I was able to reset the service indicators and intervals, thank you.
The Oil Change function was still not available, but the warning has gone, due to the service reset.
papa yankee
Post by papa yankee » 19 Apr 2018, 14:29
So, are we saying the KKL I have is not compliant?
