Multiecuscan 1.4 RELEASED!
General messages
argtv6
Re: Multiecuscan 1.4 RELEASED!
Post by argtv6 » 09 May 2013, 08:53
Hi Yani,
I haven't managed to connect using the 3-pin on 2 vehicles.
However when I scan DTC with 'optimal' KWP2000 with both high latency and normal modes this ecu shows up:
Other
UNKNOWN/UNSUPPORTED
ISO Code: 2F 86 01 94 1F
COMPLETED
Thanks & BR
Ralph
Post by yani » 12 May 2013, 19:51
argtv6 wrote:Hi Yani,
Other
UNKNOWN/UNSUPPORTED
COMPLETED
Thanks & BR
Ralph
This ISO code is correct for the hood module.
Please send me a report (from the red Send Report button in Multiecuscan) after a SCAN and after trying to connect to the hood module. I need this report to check why it cannot connect and why it says unsupported.
argtv6
Post by argtv6 » 13 May 2013, 10:07
Hi Yani.
I will send you a report when I next have a 916 Spider at the workshop probably later this week.
Thanks & BR
Ralph
Post by s130 » 16 May 2013, 09:15
MES does not support Key / Immobiliser reprogramming.
I also believe that this function is unlikely to be be supported for security / safety / reliability reasons.
drjod
Post by drjod » 23 May 2013, 18:23
hi,
is it now supporting fiat sedici airbag system?
Post by s130 » 24 May 2013, 10:25
drjod
Post by drjod » 26 May 2013, 13:32
nope, still cant access sedici airbag system, can open it but thats as far as it goes, no further info...
drjod
Post by drjod » 05 Jun 2013, 12:10
any more ideas?
argtv6
Post by argtv6 » 11 Jun 2013, 21:07
argtv6 wrote:Hi Yani.
Thanks & BR
Ralph
Hi Yani,
Today I tried again with MES 1.5 and the 3 pin connector but no ecu was detected in the scan. I sent reports.
It seems that the option of connecting with the 3 pin in the battery compartment has gone with MES 1.5.
I've just ordered purple adaptor 4 from Gendan this evening and will try with that from the dash EOBD.
Ralph
yoman91
Post by yoman91 » 10 May 2014, 21:48
Hi everybody, I wanted to check my ABS for my ALFA GTV '97 (2.0 TS), and I got this error:
ABS
UNKNOW/UNSUPPORTED
ISO CODE: 6B 02 2A 10 7C.
Can anybody help me solving this problem?
