service reset Impossible jtd
stilo
Post by stilo » 01 Jun 2010, 20:20
Hello I appear from españa and raise this question since not and found response and and looked in all the sides and it is the following one since 1.9 becomes a service reset to a consent stilo jtd with elm327 1.5? And provado bypassing the pines 1-3-7-9 and not also at all and proved with her v1.3 and nothing, it is necessary to have the version of payment? Or is it necessary to bypass algun cable mas? Very good program and graces for the help
EnIgMa
Re: service reset Impossible jtd
Post by EnIgMa » 03 Jun 2010, 19:13
what is the error message?
By the way, I should know that 1.5 version is fake, maybe it won't work because of that.
stilo
Post by stilo » 08 Jun 2010, 19:25
the error is giving me connection failed ecu ELM327 connection failed and use the ELM327 1.5a but with 1.3ay driver that comes with the setup here in the page
kayman55
Post by kayman55 » 11 Jun 2010, 13:22
I have had this problem for a long time...
ELM 1.5 is not working, you should buy an ELM 1.3.
At the ELM Cables you don't have to connect Pins. This is only necessary at KKL Cables.
stilo
Post by stilo » 16 Jun 2010, 16:06
ELM327 cable so I need the v1.3 and then I can perform my stilo service reset without problems? the v1.5 if I work with read ecu abs and airbags but the instrument panel and reset the service refuse
