Fiat Panda 4x4 312 1.3 Multijet restore Convergence telematic module
Flynello
Post by Flynello » 22 Dec 2023, 20:13
HI,
I recently bought a 2013 Fiat Panda 4x4 312 1.3 Multijet on which I changed the Convergence telematic module because I had the odometer that was flashing and the Blue & Me that no longer worked, but after the replacement when doing the Proxi and c alignment 'was: "Convergence node: Removed". Once the alignment is done, the convergence node is no longer there. Now the odometer no longer flashes but the blue & me does not work.
Can anyone help me to intervene in the Custom Proxi. Thank you.
Lettura dati configurazione CAN...
CAN CONFIGURATION DATA:
6F 04 00 15 02 00 00 00 6F 04 00 15 00 00 00 00 49 00 00 10 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 04 00 15 02 00 00 00 09 04 00 05 02 00 00 00 6F 04 00 15 00 00 00 00 09 04 00 05 00 00 00 00 09 04 00 05 00 00 00 00
30 36 33 31 39 30 30 32 30 36 31 4F 55 54 50 55 54 44 4A 49 54 20 12 09 04 6F 04 00 15 02 00 00 00 09 04 00 05 02 00 00 00 87 C0 71 07 44 01 00 71 AA 00 00 06 00 07 00 8C 06 0B 02 46 00 80 01 01 35 50 0A 1C 0D 00 00 00 17 00 00 00 00 41 04 40 00 80 00 00 00 6D 20 02 04 00 00 00
Body Computer (BCM/NBC)
Controllo motore (ECM/NCM)
Guida Elettrica (EPS/NGE)
Quadro Strumenti (IPC/NQS)
Radio Ricevitore (NRR)
Impianto frenante (ABS/BSM/NFR)
Climatizzatore (HVAC/NCL)
Nodo Sensore Parcheggio (PAM/NSP)
Nodo Air Bag (NAB/ORC)
Coupling Control Node (CCM)
Nodo convergence
(Multiecuscan 4.8)
21/12/2023 15:41:17
Fiat Panda 2012 1.3 Multijet 16V
Controllo motore (ECM/NCM): Ok
Guida Elettrica (EPS/NGE): Ok
Quadro Strumenti (IPC/NQS): EOL Ok
Radio Ricevitore (NRR): Ok
Impianto frenante (ABS/BSM/NFR): Ok
Climatizzatore (HVAC/NCL): EOL Ok
Nodo Sensore Parcheggio (PAM/NSP): EOL Ok
Nodo Air Bag (NAB/ORC): EOL Ok
Coupling Control Node (CCM): Ok
Nodo convergence: Rimosso
ESECUZIONE ADEGUAMENTO...
PROCEDURA ALLINEAMENTO PROXI
Scrittura dati configurazione CAN...
Registrazione modulo: Body Computer (BCM/NBC) ESEGUITO!
Registrazione modulo: Quadro Strumenti (IPC/NQS) ESEGUITO!
Registrazione modulo: Climatizzatore (HVAC/NCL) ESEGUITO!
Registrazione modulo: Nodo Sensore Parcheggio (PAM/NSP) ESEGUITO!
Registrazione modulo: Nodo Air Bag (NAB/ORC) ESEGUITO!
COMPLETATO
