Multiecuscan Adapters
mattydr67
Post by mattydr67 » 20 Jul 2023, 14:18
Hello guys
This post is just for information.
I bought few months ago this all-in-one adapter.
I just wanted to share my experience with you.
This all-in-one adapter replace all the colored cable adapters that I used before and I do not need to change cables during the diagnostics.
Me I am using an AVDI with the kkl/ELM interface emulator so I do not need to change the interface either.
This all-in-one adapter have something new then in the schematics of the cable. This means that for cables A1, A2 and A4 there is also CAN BUS pins 6 and 14 available and this will let me connect to CAN BUS controllers on pins 6-14 and on Kline pins and I do not change the adapters ort remove the adapter when I need to change to k-line controllers or different CAN BUS pins controllers.
This all-in-one adapter was very cheap so for me it worth because I also using with AVDI with Fiat Examiner Smart HD VMware, helping me to connect to the controllers on Kline that AVDI do not multiplexing.
Because I couldn't uploade item then I uploaded to a server
Multiecuscan all-in-one adapter picture: https://mega.nz/file/3VhVnSwY#BvDQjNR7hxtSf9HADANzINGYQbYwH6tBfTaKMwf92oA
vincenzo2011
Re: Multiecuscan Adapters
Post by vincenzo2011 » 04 Aug 2023, 16:09
Ciao Matty, dove lo hai acquistato cortesemente? grazie
Hallo Matty, wo hast du das bitte gekauft? schmücken
mattydr67
Post by mattydr67 » 07 Aug 2023, 10:34
Sure I sent you details from where I got it by Private Message.
