AR Giulietta Intrumental panel update. Need Help
altf4_by
Post by altf4_by » 19 Jun 2023, 23:11
Hello guys.
So, I have an Alfa Romeo Giulietta 2010 2.0 170hp. In this car I have an old instrumental panel with red leds. I decided to change it to a newer version with white color of the display.
I tried to make proxy alignment but it was not succeded. Then I went to instrumental panel and had these errors: U1700-86 - No Body Computer, and U1706-87 - NFR Node absent. Tried clean them, but it was impossible.
Also in bodycomputer I had the error B10AA-55 - PROXI configuration control.
Is that possible at all to use that newer instrumental panel and what I am doing wrong. Can somebody help me pls.
Re: AR Giulietta Intrumental panel update. Need Help
Post by s130 » 21 Jun 2023, 10:45
For a 500X then I get different info for the codes you quote:
5_Manual\Diagnostics_For_DTC\IPC11_Instrument_Panel_Cluster(Marelli)\ --> Body Computer Module (BCM) - Signal invalid U1700-86
5_Manual\Diagnostics_For_DTC\IPC11_Instrument_Panel_Cluster(Marelli)\ --> Body Computer Module (BCM) - Missing message U1700-87
NOTE! Every CAN Node/Unit can create this error message so i have just reference the one relevant to the Instrument Panel.
For both the diagnosis steps involves checking wiring, connectors, power,
o U1700-86 & U1700-87
o Disconnect/reconnect the instrument panel connectors and check for the presence of loose pins
o Check that the power supply to the Instrument panel is correct
o Check that the instrument panel is working properly
kubislav17
Post by kubislav17 » 28 Jul 2023, 08:15
I have the same problem, did you manage to solve it
DANIELE
Post by DANIELE » 05 Dec 2023, 14:48
on new giulietta instrument panel put byte 131 1F and proxy will be fine
kubislav17
Post by kubislav17 » 04 Feb 2024, 13:53
DANIELE wrote:
05 Dec 2023, 14:48
My proxy
30 34 31 39 31 30 30 37 32 36 36 4F 55 54 50 55 54 2D 4A 49 54 20 11 05 27 6F 0C 40 05 02 00 00 00 09 04 00 04 02 00 00 00 87 E5 51 07 8F 00 3C 20 B8 10 08 16 00 07 01 D4 06 2D 03 3C 02 00 01 00 3A 51 0A 7C 00 00 00 00 09 00 00 00 00 36 21 61 01 38 00 44 00 00 00 04 06 00 00 00
BBOinsam
Post by BBOinsam » 05 Mar 2024, 17:18
I using a HDHomerun and want to scan to pick up only a few channels.
I have a channel at 2_1 as a HDHomerun channel entry.
I recently installed a new TV and when it finished the cable scan it found 2_1, 2_2, 2_3 on the new tv.
Is it possible to scan for just those channel without doing a full scan.
I tried doing a full scan, it found them once but also added lot of other garbage channels that I dont really want. So I went back and did another scan did a manual insert option but never found the channels I wanted.
Not sure where to go from here.
