Timeout and unknown error proxy alignment Fiat bravo 1.4 t-get 2007
elektric93
Post by elektric93 » 23 May 2023, 13:32
Hello. I need advice how to solve a problem with the failed proxy alignment procedure after replacing climate control screen? The procedure fails when write info in the following nodes:
dashboard - ipc/nqs - timeout error
climate control - hvac/ncl - uknown error
I'm sharing link to a video with the procedure: https://streamable.com/r3m4c8
I'm using a bluetooth adapter
and Multiecuscan 4.6. Tried the procedure several times but with no success. I'm able to connect successfully to all available modules. Here's the log data:
CAN CONFIGURATION DATA:
05 00 84 6F 05 00 84 6F 00 00 04 00 00 00 00 00 00 00 00 00
05 00 84 6F 04 00 04 09 05 00 84 6F 04 00 04 09 04 00 00 09
30 34 31 39 38 30 30 31 33 38 31 4F 55 54 50 55 54 2D 4A 49 54 20 07 06 30 6F 84 00 05 09 04 00 04 81 00 00 07 8F 00 16 00 00 02 84 06 01 00 00 28 00 81 00 53 00 34 00 00 00 00 00 00 00 00 36 51 05 0C 01 00 00 00 3A 10 A0 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Receiver Radio/Radio Navigator Node (NRR/RMN)
Side Acceleration / Yaw Node (NYL)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
(Multiecuscan 4.6R1)
21/05/2023 13:52:58
Fiat Bravo '07 1.4 Turbo 16V
Receiver Radio/Radio Navigator Node (NRR/RMN): Ok
Climate Control Node (HVAC/NCL): EOL Failed
Side Acceleration / Yaw Node (NYL): Ok
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (IPC/NQS) FAILED! - Timeout error
Writing to module: Climate Control Node (HVAC/NCL) FAILED! - Unknown error
FAILED TO EXECUTE
elektric93
Re: Timeout and unknown error proxy alignment Fiat bravo 1.4 t-get 2007
Post by elektric93 » 25 May 2023, 06:05
Anyone? Adapter is able to do the procedure, verified by the shop\
