I have airbag light on my Fiat Ducato 2.3 year 2017.
I have vag kkl interface and red an yellow adapter cable
Which adapter cable should use and will I be able to read airbag computer ?
I tried search for topic to help me no luck.
Airbag Fiat Ducato setup ?
Re: Airbag Fiat Ducato setup ?
I know you posted this a little while ago, but having just been in the same position I thought i'd answer to help anyone else. I used the yellow adapter to read my x290 Airbag ECU codes, which unfortunately confirmed a fault within the ECU. Looks like i'm off to source a repair or replacement!
