Template use
CheeseMonster
Template use
Post by CheeseMonster » 10 Jan 2023, 21:34
When I create a template I can see it in the Parameters > Templates menu, I can see all ten templates (0 to 9) and the parameters I've selected. I then select the template I want to use and click OK.
At this point I have no idea visually that my template is loaded, the parameter list is the same no matter which template I select and no parameter is ticked or highlighted in red.
Can someone offer some help please?
CheeseMonster
Re: Template use
Post by CheeseMonster » 12 Jan 2023, 17:01
I'm trying to use Templates but I still can't, so hoping this update will get me the answer?
If I create a template with one parameter in template 0 (zero) and then load that template I get a page displaying ever parameter not the single parameter from my template.
This can't be right!
I would attach images but the forum doesn't allow that!
Is there a way of contacting who ever writes MultiECUScan?
Re: Template use
Post by s130 » 16 Jan 2023, 08:52
Templates do NOT change the number off parameters visible in MES. The templates are so you can have one or more specific parameters selected to monitor. e.g. Template 1: RPM and Temeprature. Template 2: Battery Voltage and Vehicle Speed and Odometer.
