Fiat Barchetta cannot connect to air bag ECU
shpuncik
Re: Fiat Barchetta cannot connect to air bag ECU
Post by shpuncik » 07 Nov 2022, 18:14
possible causes:
- bad cable;
- wrong cable setup, latency time, fake FTDI chip;
- airbag ECU itself is a toast;
old dear
Post by old dear » 07 Nov 2022, 18:48
shpuncik wrote:
07 Nov 2022, 18:14
possible causes:
- bad cable;
this is the bit i cannot get my headround if i plug the same set up into the engine ecu 3 pin it all works great without a problem
and i can get the blink codes ok manually from the airbag ECU 3 PIN but it wont connect with the KKL .....
think i need a beer
night all x
old dear
Post by old dear » 09 Nov 2022, 07:19
OK folks the latest....
multiecuscan connects to the engine ECU 3 pin with leads no problem
plug the same set up into the airbag 3 pin , set the multi scan on connect ,press Y and the multiscan will not connect BUT the air bag light goes out for approx 3 seconds then starts to Blink 3 times and the light comes on again permently .....so something must be connecting somewhere.
any ideas folks ?
thanks
(the 3 blinks are coming up in the fiat manual as" Module activation circuit coming into contact with 12 volts " but its only blinking 3 times when the laptop is connected by pressing Y on the multiscan )
shpuncik
Post by shpuncik » 09 Nov 2022, 10:22
parts catalogue shows couple different airbag ECUs and seems like early models didn't use TRW ECU. might be your problem.
old dear
Post by old dear » 09 Nov 2022, 10:32
shpuncik wrote:
09 Nov 2022, 10:22
yes thats a good point i will see if i can find out what ecu is in it ,thanks for your help
Post by s130 » 09 Nov 2022, 10:55
If you PM me your VIN I'll look up the part number for your airbag ECU. From that we can probably find the make.
old dear
Post by old dear » 09 Nov 2022, 13:00
s130 wrote:
09 Nov 2022, 10:55
will do tonight many thanks
Post by s130 » 10 Nov 2022, 10:51
Have replied to you directly.
Looks like your Airbag ECU is an early one and pre TRW.
