ELM327->ECU Connection failed!
Ronthedob
Post by Ronthedob » 10 Sep 2021, 18:20
Connection is fine to engine but I can't connect up to the Service.
Error message:
  • "Connection Failed
    Check your cable and serial port settings"
Any ideas on what is wrong?
Ron
Ronthedob
Re: ELM327->ECU Connection failed!
Post by Ronthedob » 20 Sep 2021, 11:44
USB cable replaced.
All settings as recommended in the Multiecuscan user guide.
Connection to "Engine" always works correctly.
Connection to "Service" gets the error message.
Windows 10 Pro 64 bit, updated.
Any ideas on what is wrong? Answers much appreciated.
Ron
Post by s130 » 20 Sep 2021, 19:16
What vehicle Make and Model and Year and Engine Type (diesel/petrol) and CC.
Ronthedob
Post by Ronthedob » 20 Sep 2021, 21:16
It's a Fiat Doblo. 2006. 1.9 multijet diesel.
Post by s130 » 21 Sep 2021, 06:46
Looking at the Doblo listings there are quite a few. What Type Number is your Doblo.
I ask because a) you might need an adaptor cable A3 or (b) despite Service saying ELM a KKL interface may be required. With (b) the software does not tell you this.
Ronthedob
Post by Ronthedob » 21 Sep 2021, 10:25
Hi and thanks,
From the Multiecuscan website:
"Fiat Doblo (type 119) 1.9 JTD/Multijet
Bosch EDC15C7 CF3/EOBD Diesel Injection (1.9 8V, 2.4 10V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9 16V, 2.4 20V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Teves MK20/MK70 ABS |INFO|DTC|PRM|ACT| KLELM A1 P1
Autoliv Airbag MY99 |INFO|DTC|PRM|ACT| KL A2 P3
Service Interval Reset (Base) |INFO|ADJ| ELM
Service Interval Reset (Comfort) |INFO|ADJ| ELM
Instrument Panel Marelli |INFO|DTC|PRM|ACT|ADJ| ELM
Instrument Panel Marelli (Base) |INFO|DTC|PRM|ACT|ADJ| ELM
Instrument Panel Marelli (Comfort) |INFO|DTC|PRM|ACT|ADJ| ELM
Body Computer Delphi/Marelli (188) |INFO|DTC|PRM|ACT|ADJ| ELM
Body Computer Marelli (188FL) MY03 |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
CAN Info |INFO| ELM
CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELM"
It all worked ok last year and I could access the "Service" tab and do the reset.
This year I'm using the same kit as last year but now I'm getting this error message.
Can't fathom out what is wrong.
Any help very much appreciated.
Cheers
Ron
Post by s130 » 21 Sep 2021, 17:37
OK.
Do again and then use the "Send Report" (along bottom of MES screen) and then EMail MES Support.
Ronthedob
Post by Ronthedob » 21 Sep 2021, 18:11
Thanks,
Will do.
Ron
Ronthedob
Post by Ronthedob » 02 Oct 2021, 09:23
Went to do the "Send report" and found it has miraculously got itself fixed.
Probably down to a Windows issue.
Laptop did another update and now "Service" function is back.
Ron
