Key fob reprogramming US Giulia
Posted: 06 Aug 2021, 16:36
by Erdemtheman
Is it possible to reprogram a new key for a US Giulia using MES? Or, do I need to take the car and the key to the dealership?
Re: Key fob reprogramming US Giulia
Posted: 07 Aug 2021, 15:00
by shpuncik
need PIN code which only dealer can supply when connected to car. or locksmith should be able to pull it from car.
Posted: 07 Aug 2021, 18:10
by Erdemtheman
Thank you. Once I have the PIN, what’s the procedure in MES to reprogram a new (blank) fob? Appreciate the info.
Posted: 08 Aug 2021, 12:06
by shpuncik
just run MES in Simulation mode and see for yourself under RFHUB. it's pretty straight forward procedure.
however I have tried to program used virginized key and that didn't work, instead used some designated equipment for that. never tried to do it with brand new OEM key though.
Posted: 08 Aug 2021, 17:23
by Erdemtheman
Awesome. I was just wondering what section key programming was under. Thank you for the info. I have heard that these original fobs are one time programmable so if you mess up the procedure, it’s done.. so I’ve heard.
I will familiarize with simulation first then figure out the rest.
Thank you.
