Page 2 of 3
Re: Convergence Telematic Module (Blue&Me) Removal
Posted: 28 Jun 2021, 13:47
by DaveDevil
You can PM me after 11 July, or for sure I'll forget it :roll:
Posted: 28 Jun 2021, 14:00
by shpuncik
JDalfa wrote:
28 Jun 2021, 13:11
Ok maybe you can let me know when you’re back home.
Or if anyone else can help please let me know!
Thanks!
go to proxi settings, press Ctrl+Alt+C and there you can edit your proxi manually
Posted: 29 Jun 2021, 08:24
by JDalfa
Tried that with simulation, so i just change the 38th digit combinition i count from 42 to 02?
Thnx!
Posted: 29 Jun 2021, 09:27
by DaveDevil
Yes. Be sure to backup your original proxy so in case of problems you can roll it back
Posted: 29 Jun 2021, 15:44
by JDalfa
Thanks, gonna try that! Also disconnect the radio with battery disconnected?
Posted: 29 Jun 2021, 17:53
by DaveDevil
Sure, better that way
Posted: 30 Jun 2021, 16:17
by JDalfa
It worked perfectly, thank you!
Is there a list of the custom proxy digits, wat they do/mean?
Kind Regards joost
Posted: 30 Jun 2021, 16:33
by DaveDevil
I wish it were, things like that are the holy grail, and who knows that things usually keeps it secret, donating only few drops once in a while...
Posted: 20 Oct 2022, 12:43
by Jeff1985
Hi. Did you manage to do a proxy alignment without your blue and me?
Mine is faulty so it’s made the mileage flash. Keep trying to do an alignment but it fails when it try’s to do the convergence telematic node. Can I change the code so it thinks it’s not there?
Posted: 21 Oct 2022, 05:52
by DaveDevil
Jeff1985 wrote:
20 Oct 2022, 12:43
Yes. Follow the video in the older posts, then disconnect your module while you disconnected the battery. Then do an alignment
