Fall and rise rpm after used connection.
kylo80
Post by kylo80 » 21 Apr 2010, 21:39
My English is bad, sorry about this ;)
The first time I used this program in version 2.1 free.
If I connect laptop to car and starting the engine, engine speed increases spontaneously. Then, fall and rise.
Restart the car's not helped.
Helped remove clamp from the battery.
Do You know what was causing this strange behavior of engine?
Thank You for any information.
My car: Fiat Punto 2, 2003, 1,2 8V
erkki
Re: Fall and rise rpm after used connection.
Post by erkki » 13 Feb 2011, 21:42
I had the same problem once in my Punto mk2b, 2006, 1.2 8v.
EnIgMa
Post by EnIgMa » 14 Feb 2011, 21:06
here too on fiat punto 2004 1.2 8v
It is a know "issue".
Someone (like me) fix it turning off the engine, someone else have to remove clamp from the battery.
I don't know why this happen, but it's not that big deal.. ;)
Post by yani » 15 Feb 2011, 08:39
Is it possible that this happens after executing some actuator command?
Or it happens every time you connect to the engine (without executing actuator commands)?
erkki
Post by erkki » 23 Feb 2011, 18:03
I don't remember what I was doing, but it has been happened only once.
EnIgMa
Post by EnIgMa » 02 Mar 2011, 12:02
In my case i execute actuator test.
