About Vag com k line cable
suleyman_23
Post by suleyman_23 » 26 Jul 2020, 17:32
Hello all, I thinking buy a vag com k line cable, for my fiat marea 2004 exclusive 1.6 16v engine; 182B600xxx. Can I log in dashboard this production, or I should buy a elm interface ( 2 device) Example turn on-off security belt light? Sorry my english thank you.
Re: About Vag com k line cable
Post by s130 » 27 Jul 2020, 07:35
Look here: http://www.multiecuscan.net/SupportedVehiclesList.aspx
You will see that you can only connect to Engine, ABS and Airbag systems. The dashboard and other units are not supported.
However a VAG / KKL interface is all you need for connecting to the engine PLUS adaptors A1 and A2 if you want to connect to the ABS and Airbag systems.
Fiat, Marea '01, 100 16V/CF3
Magneti Marelli IAW 4AF/4EF/59F/5AF EOBD Injection |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Magneti Marelli IAW 4AF/4EF/59F/5AF Injection (Outside EU) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Lucas EBC 430 ABS |INFO|DTC|PRM|ACT| KLELM A1 P1
Allied Airbag MY97 |INFO|DTC|PRM| KL A2 P3
Breed Airbag MY97 |INFO|DTC|PRM| KL A2 P3
suleyman_23
Post by suleyman_23 » 27 Jul 2020, 11:48
Thank you for reply. Excuse me I’m new here, I reading supported vehicles list but I cannot understood. For example; Yellow ground INFO -ACT-ADJ What is mean? And, what is red ground A1 A1? If you explain me, I will be very happy. Finally I need a adaptor vag com adaptor A1 or A2?
Post by s130 » 27 Jul 2020, 14:48
|INFO| - Identification data reading is supported on the module
|DTC| - Error codes reading and clearing is supported on the module
|DTC EX| - Error code details reading is supported on the module
|PRM| - Parameter reading is supported on the module
|ACT| - Actuator functions are supported on the module
|ADJ| - Adjustment procedures are supported on the module
To connect to the engine module you need no adapters
To connect to the ABS you need adapter A1
To connect to the Airbag you need adapter A1
The P1 means Pin1 is used instead of the normal Pin 7
The P3 means Pin1 is used instead of the normal Pin 7
suleyman_23
Post by suleyman_23 » 27 Jul 2020, 16:02
this is the product I ordered. According to the information, ABS airbag connection is possible. do I still need A1 A2 adapters?
https://www.hepsiburada.com/oto-eko-fiat-alfa-romeo-arac-ariza-tespit-cihazi-vagcom-vag-kline-multiecuscan-vagkkl-p-hbv00000rqujg
Post by s130 » 28 Jul 2020, 06:55
With that switched unit you DO NOT need any adapter cables.
The switch does the pin change over for you.
suleyman_23
Post by suleyman_23 » 28 Jul 2020, 08:09
s130 wrote:
28 Jul 2020, 06:55
Thank you s130, have a nice days :)
