Parameters not working in FREE version
petarbg
Post by petarbg » 21 Apr 2020, 18:17
I cannot access no parameters in the Engine or Gearbox menu in the free version. I have Alfa 147 TS Selespeed, 2001. I wanted to check the program before I buy the registered version, but not one parameter is wotking - not coolant temperature, engine temperature... nothing, and as far as I see the free version should support 4 of these.
I use 1.5V Elm327 with USB. I connect to the ECU but pretty much I cannot do anything from there. I also don't see Software version and so on in the Info panel. Can you tell me what I should do?
