Hi all,
I replaced the radio on my Bravo II 198 (Brazilian, 2016 model) for an aftermarket one. Since the radio (uconnect 5) was removed, the odometer is blinking.
I tried running a proxi alignment but the result is the same, the radio still lists as present. How can I disable it? Do I need to run it with the original radio plugged in?
Thanks,
Marcos
Proxi alignment - removed radio - Bravo 198
Re: Proxi alignment - removed radio - Bravo 198
I have the same problem with a bravo 198.
After connecting tio the car and startiing the proxy window i see 4 removed modules, did you have that too?
Is there already a solution?
Many Greetings from Germany
