Speed limit (FROM PROXI)
Diongio87
Post by Diongio87 » 20 Jun 2019, 18:51
Hey guys, can anyone help. I've gone through the process of trying to remove speed limiter. The normal adjustment of the five options haven't helped it isn't set via that. Then I came across In Parameters below normal speed limit parameter is: speed limit (FROM PROXI) and is set to 100 km/h I've been through every possible module and setting and can't change it. Is this something outside the powers of mes? Cheers
