Desired Air Quantity not rising on idle
cac
Post by cac » 05 May 2019, 21:25
hi, I've got some fuel consumption/acceleration issues in Tipo 1.6 MJ and started to look after air flow/temperature readings and found something really strange. If I push acceleration pedal on idle, Air Quantity rises but Desired Air Quantity does not. How can it be? How DAQ is being calculated btw? I'm not sure if I can relay on readings while driving if it seems not to work on idle.
When driving mostly DAQ and AQ equels but sometimes they not (same situation - AQ is much higher then desired) - the question is if driving readings are accurate then or not?
here is example: Image
red -vehicle speed
green - rpm
dark blue - intake air quantity
light blue - desired air quantity
