Obd scanner must be ducato/boxer/relay compatible.
Jonnytatt
Post by Jonnytatt » 26 Apr 2019, 05:41
I need the Multiecuscan for my fiat ducato 2.2 which is on the list but Will the Multiecuscan work with the Citroen Relay and Peugeot Boxer which is the same engine and built on the same production line as my friend has a Boxer and would like to use the scanner also.
the1andonly
Re: Obd scanner must be ducato/boxer/relay compatible.
Post by the1andonly » 18 Feb 2024, 18:38
For any body searching.
The 2.2 2021 Ducato is not the same engine as the boxer relay 2.2
The ancillary ecus should be read.
