How to reconcile "Engine ECU Status"?
mprowe
Post by mprowe » 11 Apr 2019, 09:00
I am using MES 4.0 with a Genuine OBDLink SX USB interface to a Fiat Ducato x250 2.2 Multijet.
In the "Body Computer | Parameters | Engine ECU Status" it reports "Faulty"
... while the "Engine | Parameters | Engine ECU" reports "Programmed"?
Are the two parameters looking at the same source? Or is there some other explanation?
Additionally, the "Body | Parameters | Code from engine ECU" reports "Not received"?
When should this parameter "Receive a value"? Or is the fact that no values are being received, the cause of the "Faulty" report (listed above)?
Best regards, Martin
