punto 1.2 8v petrol - ecu adaptiv reset
Scimitargte
Post by Scimitargte » 07 Jan 2019, 11:47
did an adaptive reset as per instructions ie 'execute' followed by engine warm up and rev to 5500rpm holding it at these revs for 3 seconds - rrepeat 3 times but mil continues to flash, no faultt codes --- do I have to drive a few miles for it to relearn and switch off the mil??? help as mot due soon and not sure garage will test with a flashing mil although new regs say no test if mil is pernanently illuminated
Scimitargte
Re: punto 1.2 8v petrol - ecu adaptiv reset
Post by Scimitargte » 13 Jan 2019, 21:13
Anyone, an Idea/suggestion?.
kido.resuri
Post by kido.resuri » 19 Jan 2019, 17:52
Any fault codes stored?
The described method should work...
https://www.puntonium.hu
Scimitargte
Post by Scimitargte » 21 Jan 2019, 22:08
Hi, no fault CODes done the execute then revved to 6k 3 times numerous times lamp will not extinguish
