Incorrect Conditions - Replacement of Control Unit and Injectors
Posted: 30 Nov 2018, 17:18
by chrisken
I'm trying to use the "Replacement of Control Unit and Injectors" function in multiecuscan after fitting and programming new injectors on my 2.4 jtdm and the software is saying "Failed to execute" "Incorrect conditions to run the test".
Any idea what the correct conditions should be?
Thanks.
Re: Incorrect Conditions - Replacement of Control Unit and Injectors
Posted: 02 Dec 2018, 21:25
by gionag
Same situation here...
i get "failed to execute" and nothing else
Posted: 03 Dec 2018, 12:28
by chrisken
Mine says incorrect conditions with the engine on and failed to execute with the engine off. Either way it doesn't work. Tried everything I can think of. Wondering if it's a problem with the software? Everything else works fine with it.
Posted: 03 Dec 2018, 19:47
by gionag
i have licensed MES... version 4.3
tested both with ELM (clone) and KKL.
same errors...
i have orderer a genuine elm 2.2 chip and intend to swap that with the chinese clone and see if something is missing
Posted: 10 Dec 2018, 11:56
by chrisken
Same here. Let me know how you get on with the genuine elm device. My only other thought was to transfer my MES licence onto a different laptop to try that - but it seems like a bit of a long shot. It just seems so odd that everything else on the software that I've tried is working perfectly except this function.
Posted: 13 Dec 2018, 14:03
by gionag
Got that....
i don't think the switch of the platform will fix anything... but if it's not cost you much, you can always test.
I am waiting packet from canada...
keep you posted !
