Uconnect 7 (touch) activate DAB and NAV (Fiat500)
ildiko
Post by ildiko » 10 Nov 2018, 17:18
I have changed my naked standard radio in my Fiat 500 to a 7" HD touch-model 2018 with DAB and NAV and an TFT-odometer.(both from Abarth version)
after some attempts to proxy allignment everything succeeded.
BUT!!!
- before proxy allignment my radio worked with DAB-reception. It had animations from Abarth in the odometer and on the Radio.
- after proxy allignmet, errors in OBD were gone (no more blinking kilometers) but DAB is gone :-(((
I managed to enter engineering mode on radio by pressing "Display"+"Mute"+"Browse" and found out, that DAB is 0x0 (turned off)
but where in MES can i change this parameter???
Help me, Obi-Yani-Kenobi. You're my only hope.
Vicky
ildiko
Re: Uconnect 7 (touch) activate DAB and NAV (Fiat500)
Post by ildiko » 11 Nov 2018, 05:44
here is my proxy dump:
33 32 31 35 30 30 31 34 31 39 35 4F 55 54 50 55 54 44 4A 49 54 20 15 07 18 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 01 C0 73 06 DB 00 1C A0 3A 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 01 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D 00 94 00 21 00 04 88 02 00 10 00 00 00 40 00 81 00 0F 00 00 00 00 01 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00
quinientos
Post by quinientos » 11 Nov 2018, 19:22
ildiko wrote:
10 Nov 2018, 17:18
BUT!!!
Vicky
your Fiat 500 is from 2018? Was your previous radio Uconnect 5? How did you made the process of allignment to have success?
I'm trying to do the allignment from uconnect 5 to uconnect 7 and allways I get a mistake ¿?
quinientos
Post by quinientos » 11 Nov 2018, 22:31
ildiko wrote:
10 Nov 2018, 17:18
BUT!!!
Vicky
Have you changed the Uconnect 5 to Uconnect 7? Is your car from 2018? I removed my Uconnect 5 and I'm trying to allign my Uconnect 7 but I can't do the process with success. Could you explain the entire process to allign your new unit, please?
Malse
Post by Malse » 12 Nov 2018, 18:17
ildiko wrote:
10 Nov 2018, 17:18
BUT!!!
Vicky
I have changed my radio on my 500 from a 7” with nothing to a 7” with Tomtom, does your uconnect work? Mine is not working after changing radio
joypower
Post by joypower » 19 Oct 2020, 13:22
@ildiko have you solved your problem?
