Fiat 500 Proxi Alignment
Posted: 17 Oct 2018, 20:23
by Woogie
I have a cantiecar interface and software 4.2.
I have been trying to proxi align a 2010 Fiat 500 1.2 8v. The process fails on airbag and I get this message NAB/ORC EOL failed. I have communication with the airbag, here is the report I generated.
CAN CONFIGURATION DATA:
6F 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 09 00 00 00 00 00 00 00 01 00 00 00 00 00 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 33 32 31 35 30 30 30 33 36 30 37 4F 55 54 50 55 54 2D 4A 49 54 20 09 12 12
6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 12 C0 71 06 F4 00 19 00 AA
00 00 06 00 01 00 14 06 01 01 00 00 00 00 00 7A 41 0A 0C 0D 00 00 00 23 00
00 00 00 11 05 11 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Receiver Radio (NRR)
Airbag Node (NAB/ORC)
(Multiecuscan 4.2)
17/10/2018 18:50:21
Fiat 500 1.2 8V
Body Computer Node (BCM/NBC) EOL Ok
Engine Control Node (ECM/NCM) Ok
Electric Steering Node (EPS/NGE) Ok
Dashboard Node (IPC/NQS) EOL Ok
Receiver Radio (NRR) Ok
Brake System Node (ABS/BSM/NFR) Ok
Airbag Node (NAB/ORC) EOL Failed
Can anyone shed any light on this ??
Re: Fiat 500 Proxi Alignment
Posted: 01 Jun 2020, 07:42
by johnny
Hello, did you get to the bottom of the Airbag node EOL failed? I have the same problem after changing out a dead ecu.
Cheers,
