Failed to connect to Body Computer
ThreshNL
Post by ThreshNL » 12 Sep 2018, 13:38
Hi all,
I'm trying to connect with my Fiat Grande Punto T-Jet (2008) in order to activate cruise control. However, i can't connect to the car. All the COM ports are fully functional but i still get the message "Failed to connect to Body Computer" when i try to connect. What am i doing wrong?
-ELM327
-Multiecuscan 4.2 REGISTERED
Thanks in advance,
ThreshNL
Leonardo87
Re: Failed to connect to Body Computer
Post by Leonardo87 » 26 Nov 2018, 17:41
ThreshNL wrote:
12 Sep 2018, 13:38
Hi all,
-ELM327
Thanks in advance,
ThreshNL
Take a look right here...
http://forum.multiecuscan.net/viewtopic.php?f=5&t=1493
Good luck! (I'm trying to connect too)
kido.resuri
Post by kido.resuri » 21 Jan 2019, 20:54
Usually if you can connect to the engine but not other modules, than your ELM has bad termination resistor on CAN line. After removing (and even better: adding proper termination), it should work.
Only if you have FTDI USB IC in it and PIC microcontroller.
Cheap fake chinese clones are totally useless.
https://www.puntonium.hu
