Speedometer and shift indicador not working after proxi alignment
aobarbosa
Post by aobarbosa » 21 Feb 2018, 14:48
My car speedometer and shift indicator stopped working after running proxi alignment. This problem had already happened before and it was solved after running proxi alignment one more time. But this time I tried to run it several times, it finishes successfully, but the problem persists. Any idea to solve it?
alex-et3
Re: Speedometer and shift indicador not working after proxi alignment
Post by alex-et3 » 03 Mar 2018, 15:30
aobarbosa wrote:Hi,
Are you sure the odometer works and has no problems ??
