Cant clear airbag errors ...
Keepcool
Post by Keepcool » 10 Dec 2015, 14:21
Hello guys
I have the airbag light in Red, so i have an airbag problem
I connected my pc to my Fiat Stilo Jtd 115cv 1.9 (2003), with the multiecuscan and the KKL Vag cable.
I found the error : "0F - Side Airbag (Passenger) "
But I cant delete the error ....
So I have 2 questions :
1) the error code concernes wich part of the airbag ? In the chair ? Or beside the chair , directly in the car ? Or in front of the chair ?
2) why i cant delete the error ?
Thanks a lot
Re: Cant clear airbag errors ...
Post by alfa156sarajevo » 19 Jan 2016, 14:03
So you need to disconnect and connect orange-yellow connector in the trunk.
Open the trunk. You have textil part in trunk. On the right side, remove the textil part. Under textil part you have to find the yellow wire with orange connector.
Disconnect it and connect it back again. Delete errors and no problem any more...
