Injection timing
Micke
Injection timing
Post by Micke » 12 Mar 2015, 14:02
Hello. I have the following question. What does parameter Injection timing ? Whether it should be 0 degrees? I it varies from 0.5 to 2.8 degrees. Auto Bravo 07 1,4 Turbo 16V. Thanks!
Re: Injection timing
Post by alfa156sarajevo » 29 May 2015, 22:32
I read in some book or manual or somewhere else (i can not remember), when this parameter is bigger than 3 or 4 (i cannot remember which number was) then you have a problem... ;)
In your car everyting is OK.
romko
Post by romko » 21 Oct 2019, 08:45
in my Bravo sport t-jet it equal to 0.69 degree after I changed timing belt, but before i'm pretty sure it was 0 degree
should I worried about that?
