PURPLE ADAPTER # 4
Re: PURPLE ADAPTER # 4
Post by Waltomatic » 14 Oct 2014, 17:45
Hi Eddy
Just out of curiosity (and desire to learn, of course), which the Fiat system uses the L line (pin 15)?
Post by Alfaeddy » 14 Oct 2014, 19:30
Hi Walter
OK :)
not that I know of
In older VW, the pin 15 is still needed :roll: :)
Post by Waltomatic » 14 Oct 2014, 19:49
Alfaeddy wrote:Hi Walter
OK :)
not that I know of
Ho Ho Ho ............ BUT VWs do not use the FIAT 3-pin adapter, right?
:mrgreen:
Post by Alfaeddy » 14 Oct 2014, 20:57
OK :)
not that I know of
:mrgreen:
Right !! :D :D
seamaster
Post by seamaster » 15 Oct 2014, 05:31
Hi Waltomatic,
The hood Module is the ecu for the electric Capote/Soft Roof.
I am still wandering if any Spider owner can check if they can connect on 16 Pin port.
Also, if you have the 3 pin in the battery compartment.
Thanks guy,
Cheers
Post by Waltomatic » 16 Oct 2014, 14:20
Tank You!
seamaster
Post by seamaster » 13 Nov 2014, 02:35
Yani solved the problem with new version 2.2.
gilou
Post by gilou » 03 Jan 2015, 09:22
I am interested in that topic. I have an Alfa Romeo spider of 2003, and same problem than you trying to access electric hood diag. It works for all other diag but not for the hood with purple adaptor!! And I am using MES 2.3.... did you try with 2.3?
thanks,
gilou
Post by yani » 03 Jan 2015, 11:57
gilou wrote:Hi,
thanks,
gilou
Most Spiders use a 3-pin adapter for the electric hood. See here
viewtopic.php?f=3&t=4281
gilou
Post by gilou » 03 Jan 2015, 13:14
I don't have this cable, but it should not as per the supported vehicle list:
Alfa Romeo
Spider '03
2.0 JTS
Bosch Motronic MED7.11 EOBD Injection |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMOBDKey
Bosch ABS 5.3 ASR |INFO|DTC|PRM|ACT| KL 1OBDKey 1 A1
TRW MY97 Airbag (2F-2P) |INFO|DTC|PRM| KL 3OBDKey 3 A2
TRW MY97 Airbag (2F-2P-I) |INFO|DTC|PRM| KL 3OBDKey 3 A2
Harrison climate control |INFO|DTC|PRM|ACT|ADJ| KL 9ELM 9OBDKey 9 A1
Electric Hood Control DURA |INFO|DTC|PRM|ACT| KL 13OBDKey 13 A4
