fiat Stilo 1.6, no work done on cable.
xpmods
Re: fiat Stilo 1.6, no work done on cable.
Post by xpmods » 23 Feb 2010, 07:17
hi i had the same problem i tryed everything then after readin loads i went here and downloaded this driver works perfectly now.
the driver that comes with the lead uses normall windows buffers you need to update these from here LATEST FTDI CDM Drivers 2.06.00
http://www.ftdichip.com/FTDrivers.htm
THATS IF YOUR LEAD HAD THIS CHIP INSIDE IT MOST HAVE.
check my other posts m8. :D
cw13666
Post by cw13666 » 24 Feb 2010, 10:14
I read your posts and tried that! But still didn't work :-(
Cable led light is lighting up so think I'll need to get hold of another laptop to try!
Deckchair5
Post by Deckchair5 » 27 Feb 2010, 13:40
It worked straightaway on my 2002 1.6 Stilo and I was able to read fault codes and run all engine parameters and graphs. Superb software. Well done Yani!
Nice to be able to save the data to a csv file and view later in Excel too
Excellent job!
