Elm 327 v.1.5 (V Gate Bluetooth) Connect problem
Post by Alfaeddy » 13 Aug 2013, 17:35
Hello Jordandc
You are very obstinate :-)
The easiest way is if you were to buy another ELM interface you :-)
But it's worth an attempt
I have a red dot and a yellow marked follow these two points on the back and select this please
DSC_0050 markiert.jpg (300.02 KiB) Viewed 7892 times
Jordandc
Post by Jordandc » 13 Aug 2013, 17:39
I dont want to buy another because it could be another faulty.
Bez tytułu1.png (1.14 MiB) Viewed 7891 times
Hmm maybe one of them is to remove
Bez tytułu11.png (1.11 MiB) Viewed 7891 times
Post by Alfaeddy » 13 Aug 2013, 20:14
Hello Jordandc
This ELM interface is modifed for Multiecuscan and CAN bus
The dealer has rebuilt it according to my information.
http://www.ebay.de/itm/151018227295?ssP ... 1423.l2649
Jordandc
Post by Jordandc » 13 Aug 2013, 21:08
What do you think about that 2 resistors?
Post by Alfaeddy » 13 Aug 2013, 21:40
Hello Jordandc
This Resitoren have nothing to do with the bridge resistor .
Has 120 ohms and connects the CAN high and CAN low wire together
I can find no bridge resistor on your board.
Jordandc
Post by Jordandc » 13 Aug 2013, 22:02
so it seems like this interface is good?
Post by yani » 14 Aug 2013, 06:47
Did you run the ELM "Test" in Multiecuscan Settings->Interfaces (button "Test" next to the interface selection)?
Can you do that and post the results here.
Jordandc
Post by Jordandc » 15 Aug 2013, 12:10
RESPONSE: ATZ
ELM327 v1.5
ELM327 v1.5
Ten interfejs jest zgodny z ELM 327 1.4! Powinien się połaczyć ze wszystkimi modułami CAN.
so its say that i can connect to all can modules, but i cant.
I was automatically paired my bluetooth on port 45 this is discovered as BT Port.COM45
i also wanted to update this port 45 as ftdi drivers but if i want to do that i receiving error code 10.
My system windows 7 starter 32bit
Post by Alfaeddy » 16 Aug 2013, 22:08
Hello Jordandc
The statement after the test
"The interface is compatible with v1.4 and alll CAN protocols can thus be read"
Has no significance, as it appears in almost all ELM or OBD interface.
But it was worth a try.
Unfortunately, I do not go on because you have tested everything.!
The transmission rate changed! (baud) has not helped.!
The driver installed was not helpful!
The only thing you could still try, try again another
COM to select port, com port 1-3, a high Com port may cause problems.
If this is correct, I do not, but a friend has claimed this.
Try it once
emiosca85
Post by emiosca85 » 13 Dec 2013, 16:46
Have you solved the problem? I have the same one!
