Noobie - Adapter 3/Yellow Question
superuno
Post by superuno » 30 May 2013, 21:30
Noobie alert!
Just bought the software and it works great for the engine ECU, already used it to log start-up voltage which shows battery voltage dropping to 8.8v which i think shows the battery is knackered and could be the cause of the starting issues.
However the main reason for getting the EML and software was to try and sort out odd issues with the CAN / Body Control computer controlled things like the lights (which currently) don't work unless you pull out a relay and then they work for a bit.... However i keep getting this message :-
'Connect Adapter 3/Yellow'
a) Does this go between the EML and the car ODB port ?
b) Where is best to get one from ?
Re: Noobie - Adapter 3/Yellow Question
Post by Alfaeddy » 30 May 2013, 22:07
Hello superuno
If the selected control by this adapter polls
you need to also use this otherwise you can not connect to diesr control
It is the one you have modified ELM Interface
This adapter you can get depending on where you're from
at the end of this web merchants are given in the various countries
Alternatively, you can order here.
http://www.ebay.de/itm/151015670657?ssP ... 1438.l2649
Juggers2k
Post by Juggers2k » 03 Jun 2013, 12:15
...or if you're in the UK, to save you the international shipping:
http://www.gendan.co.uk/product_FESYELLOW.html
http://www.ebay.co.uk/itm/160903327377
