not connect to engine ECU
Posted: 03 Feb 2010, 17:38
by pinout
Today I tried multiecuscan on my alfa 147 jtd 115cv but does not connect to engine ECU, which is the problem? but works well with ABS and airbags :|
Re: not connect to engine ECU
Posted: 04 Feb 2010, 08:53
by TribesMan
Do you have all pins connected in the cable? I think you need pin 7 for ECU...
And did you select the right ECU model?
Posted: 15 Feb 2010, 07:07
by laurentk
hi,
can u tell me what do u mean whan you say " u need pin 7 for ECU"??
because i've a problem to connect on my alfa, u can see here :
viewtopic.php?f=5&t=350
regards
LK
Posted: 16 Feb 2010, 07:54
by xpmods
update the drivers for your lead and reduce the buffer latency that worked for me.
Posted: 21 Feb 2010, 05:53
by laus
haló,900mhz cpu,and xp ok?
