Hitachi ECU and KKL-usb cable
Espi
Re: Hitachi ECU and KKL-usb cable
Postby Espi » 06 Feb 2010, 18:52
Same problem Multiecuscan doesnt find motor ecu (Hitachi MPI).
Multiecuscanner ABS & Airbag works fine, but motor doesnt.
Thinkpad T41 & XP + Fiatecucan 1.6
USB K-line cable & 3 pin.
Marea Weekend 1.8 ELX 2000.
Postby yani » 08 Feb 2010, 18:18
I will try to include the older Hitachi version in the next realease. It seems that a lot of cars are still using it.
On the other hand when you report that your car does not connect you can also include some more info. Like: Can you connect with other software? Do you know the ISO code of your ECU? Year of manufacture as reported by eper.
As far as I know there are 3 versions of the Hitachi ECU:
1. the 1st version is before '98
2. the second version is the pre-EOBD version and it is used after '98
3. the 3rd version is the EOBD version
Each version uses different communication protocol and commands. The program currently supports 2nd and 3rd version. The 3rd version is tested and works correctly. The 2nd version is not tested and there is a little chance that I have a problem with its protocol.
joe
Postby joe » 15 Feb 2010, 13:58
Hi Yani!
May I ask that is that 1st, and oldest Hitachi ECU used on early barchetta's (-95)?
Postby yani » 15 Feb 2010, 16:43
Yes, Barchetta is using the 1st ECU until '98.
xlemon
Postby xlemon » 10 Mar 2010, 08:54
please include support
Hitachi ECU - 1st version is before '98 in the following versions of the program.Fiat Marea 1997. Please ,please...
Espi
Re: Hitachi ECU and KKL-usb cable (multiecuscan 2.0?)
Postby Espi » 04 Apr 2010, 13:38
Espi wrote:Same problem Multiecuscan doesnt find motor ecu (Hitachi MPI).
Works with multiecuscan 2?
von.raven
Postby von.raven » 05 Apr 2010, 17:00
new version 2.0 still not work with older version Hitachi eccu (95-97) :cry: (Fiat coupé 1.8 '98 with '97 eccu)
tested wiht ELM 327 1.3a and KKL VAG
version 2.1 not supported older version Hitachi eccu too :cry:
von.raven
Postby von.raven » 20 May 2010, 17:31
Hitachi MPI - MFI 1.8 16V 1998/01 eccu from 97
eccu code 46448638
work with Euroscan Visa 1.83
ivo_lalov
Postby ivo_lalov » 23 Nov 2010, 20:07
Hi, version 2.5 has still no connection to the Hitachi ver 1 ECU.
The scanning finds out the ECU, but...
Engine
UNKNOWN/UNSUPPORTED
ISO Code: 45 85 83 94 B6
ABS works perfectly. Why you cannot include support for the engine?
Fiat Brava 1.8 16v 1997
Regards
Return to “Usage Q&A”
Who is online
Users browsing this forum: No registered users and 8 guests
